I have an orbit 4 station sprinkler timer, I don't know the model number. The first time I tried to program it i mistakingly programmed start times for programs A-C. Needless to stay, it turned on and off non stop. Then I thought what I needed to do was program each station instead of each program but that had similar results. This last time I programmed one single start time and I thought from reading the instructions it would automatically move to each station but unfortunately it doesn't move beyond station 1. What next? Please help...I'm so frustrated. FYI, it came with the house that I recently purchased.
Maybe the sprinkler head is not advancing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
SOURCE: Yardworks 59-3213-8 timer programing
I was just cleaning out a drawer and came across the instructions (two months after I worked through the setup!!). If you would like I can create two .jpg images and send them along. The original printing is pretty small. jbharynuk@gmail.com
Jack
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Look at screen > does display show Manual? As in manual mode
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
SOURCE: I have a raindrip 2
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
SOURCE: Grasslin FM1D20A 120 PLEASE....I need a
FM1D single-channel timer is difficult to program.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
http://waterheatertimer.org/pdf/fmd-20-setpoint-programming-guide.pdf
Timer flowchart starts page 3.
First step is to select format and then set current time.
Format is asking if you want 24hour or 12 hour format:
12 hour is am and pm
24 hour is military time where 11pm at night is hour 23.
Current time is simply the time right now.
Next step is to set program 1 thru 20 (P01 P02 thru P20)
Start by pushing +/- until desired program displays
Each program is set for either ON or OFF.
There are 20 memories available: 10 ON and 10 OFF.
Not necessary to use all 20 memories.
You need to set at least 1 ON time and 1 OFF time.
Make chart of on-off schedule to avoid conflicts in programming: For example ON at 7am Monday and OFF at 9am all-days-of-week will cause timer not to function as expected.
Each ON time is set for hour, minute and day.
Each OFF time is set for hour, minute and day
Press menu to terminate programming.
Add a comment for specific help with this timer.
