Yahoo Messenger Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 40402
I want delete adders book
Anonymous
Level 3:
President:
  • Master 392 Answers
  • Posted on Mar 27, 2009
Anonymous
Master
Level 3:
President:
Answers
392
Questions
Helped
150821
Points
1180
[Solution # 1]
You will need to go to your Yahoo! Email Account and delete the contact's name there first.
1. Click Contacts from in the toolboxt to open.
2. Go to the contact you wish to remove and click the box next to it.
3. Go to the top of the list and click the Delete button.
Go to Messenger. When your list of Contacts opens, right click next to the name you wish to remove and select Delete from the drop down menu. The contact will be removed here also.
Error Code 40402 pops up when trying to remove a name while in your Yahoo Instant Messenger list first.
[Solution # 2]
Quit the program, then delete the contents of the “Cache”-folder located here:
c:/program files/Yahoo/Messenger/Cache
That usually solves a lot of problems, that occur all of a sudden. Try that and see if it works
[Solution # 3]
most probably a registry error - if you do not have a registry cleaner try downloading the free version of ccleaner from filehippo
once its downloaded select 'registry' from toolbar on left hand side and run 'scan for issues' followed by 'fix selected errors' if errors are detected
use microsoft 'one care' for further check
Hope they could help you
Good luck
1helpful
Want too delate a name from yahoo address book/error code 40402
This is a yahoo server error code
It can happen if you try and try and amend contacts from your friends list before your address book
Go to yahoo mail page > contacts > address book >check box next to contact to be deleted > delete
Open Messenger.
Right click on contacts avatar > delete
I cannot delete several of my messenger contacts even though i deleted from my mail address book. when I try to delete them, I get the following error message: The last Address Book operation did not...
Seems Error Code 40402 pops up when trying to remove them while in your Yahoo Instant Messenger list first.
Glitches and Updates!!! Here's a work around though.
You will need to go to your Yahoo Email Account and delete the contact's name there first.
1. Click Contacts from your Email page to open your list of Contacts.
2. Go to the one you wish to remove and check the box next to it.
Go to Yahoo Instant Messenger, right click the name and select Delete from the drop down menu.
Error code 40402
[Solution # 1]
[Solution # 2]
[Solution # 3]
Good luck
Fix error 40402
[Solution # 1] You will need to go to your Yahoo! Email Account and delete the contact's name there first.
[Solution # 2] Quit the program, then delete the contents of the “Cache”-folder located here:
[Solution # 3]
Hope they could help youGood luck
1helpful
When i try to write something into "contact details" i receive the following error message : The last Address Book operation did not succeed due to a server error (Error Code: -40402).
If you are trying to delete a contact, delete them from your email address book first. This error usually comes up when you try to delete a contact from messenger first.
I try to delete address book entry and get message 40402 and can't delete. my friends say they can't get thru to message me. averageguy215@yahoo.com
0402 is a yahoo server error code and is triggered when you do something out of sequence - try editing your contacts details in your address book before editing messenger contact information
Error No. 40402
hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
10helpful
2answers
Error code 40402
if your trying to edit contacts in yahoo/messenger you will get error message 40402 - you have to edit them in yahoo mail address book first
How to delete address from yahoo masanger containing the address
Are you using the web version of Yahoo messenger? If so, then most likely the server error is from not being able to complete the requested action (busy server on their end) Try again later and see if it works. Hope that helps
13helpful
7answers
Yahoo Messenger List/Address Book
I have since found out that you have to actually go into your contacts under yahoo mail and delete them from that list, then it deletes them from your messenger. Found this solution on another website. Hope this helps anyone else who is having that problem.
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
