When i opened my pc blue screen has shown and says there is error in code error 0xc0000185 ..i hope could solve the problem
Unable to connect to or access a necessary device. error code 0xc0000185 . The recovery tools on your installation disc will be required. Contact your system administrator or the maker of your PC if you don't have any installation media (like a disc or USB device). Enter to try once more.
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution - Error Code 0xc0000185
Are you one of the Windows 10 users who ran into error code 0xc0000185 while using your device ? Usually this error message appears after a reboot.
If you carefully follow the instructions listed below, you will be able to windows fix error 0xc0000185 on Windows 10 in just a couple of minutes of your time.
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
