Video Game Consoles & Games Logo
A
Anonymous Posted on Sep 21, 2017
Could not creat java virtual machine
Have just bought minecraft and it will not work. Message it gives is "could not create the java virtual machine". I have tried the following: 1) install updated java version 7 update 25.2)removed java 7 and put back java 6.3)restarted computer4)Created minecraft.bat and tried to run it5)opened minecraft properties and tried various compatibility combinations.
5 Related Answers
A
Anonymous
  • Posted on Dec 23, 2007
SOURCE: Nero Vision Express 3.1.0.25
same problem, did a lot of research, no fix found, problem with nero dropping frames and not recovering. xvid codec not the issue, many people have the same problem with nero vision. bummer :(
Anonymous
  • 1894 Answers
  • Posted on Dec 25, 2007
SOURCE: problems with nero 6
once you finish the burning process the nero wont close or exit.it will be running in system tray.
in your system tray right click the nero icon and click exit
Anonymous
  • 144 Answers
  • Posted on Jun 05, 2009
SOURCE: Itunes library problem, itunes not opening
just uninstall the software and go to www.itunes.com and and download it. it automaticaly should download the one you need for your computer
Anonymous
  • 108 Answers
  • Posted on Jan 13, 2010
SOURCE: Quark file locking Error Code -54
Please make sure that the file is not open on any other system. if yes then close the file and then try to open it on the current machine
Anonymous
  • 218 Answers
  • Posted on Feb 18, 2011
SOURCE: My wife has been using
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Top Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
