Exercise & Fitness Logo
Anonymous Posted on Jul 10, 2013
Error code 02
I'd like to know what error code 02 means for this model of treadmill and if there a way to reset the error. many thanks. best regards Giacomo
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Jul 11, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4176552
Points
34435
Normally is a faulty PCA, RAM memory, or eeprom faulty. Reset the machine, and if the problem persist adjust the REED switch, see the diagram, clean it, test for open or faulty, clean the connector and tight very well.
Open the display board, and clean the ribbon cable with pencil eraser the contacts from dirty and corrosion. You can use the contacts cleaner for the rest of connector, clean it very well from dirty, corrosion. and try it. see the diagram attached.
5 Related Answers
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Anonymous
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Anonymous
  • Posted on Apr 12, 2010
SOURCE: Sears lifestyler 8.0 Treadmill EEEE error code
64d4644.jpg Wiring diagram
Anonymous
  • Posted on Apr 16, 2010
SOURCE: Error code "SI 2" for ironman triad treadmill
You need to replace the motor control board located in on the base. If your both motors work along with your display added that you've done the reclibration then you must replace this board. I did and the unit works so far. 200 dollars is what you wil be spending.
Anonymous
  • 944 Answers
  • Posted on Sep 25, 2010
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Top Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
