Posted on Mar 29, 2009
Copier code error
Hi
i have old model copier : Ricoh Nashuatec 3237 when i start it up it show me the code "U_2" i look in the table and it mean : "set kay counter correctly or enter your user code"what is it?.. i dont have user code...
pls help me
  • tzas Apr 02, 2009
    hi
    what do you mean? how do i do that?
    tnx
  • tzas Apr 05, 2009
    hey,
    first thanx for your answer.
    I followed u'r instructions and it didn't match the copier i have.
    are you sure u got the right model?
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Apr 02, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
18480
Points
85
Service program sp-9, mode 90 needs to be set to "0"(off). also, the key counter shorting connector must be removed.
that should disable any key counters.
  • Anonymous Apr 02, 2009
    on the left of the op panel, there should be 2 covers to remove. underneath, there is a dip switch. with the power off, change sw 902 bit 8 to "0". when you turn the power back on, the guidance display will prompt No. 5.
    you should now press "9" "0" "enter(#)". "1" should show up in the display. select "0" "enter(#)". this will disable user code mode. after this is done, shut the power off.
    before turning the power back on, you will also have to remove the key counter shorting connector, it is located under the right hand side of the op panel. ther should be 2 plugs dangling. one appears to have a cap on it, remove it. the other will then plug into it after you have removed the shorting plug.
    this should now work properly for you.
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
