Canon imageRUNNER 7200 Copier Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does E000020-0010 error code mean?
What does E000020-0010 error code mean and what do I need to do to fix it?
millstones
Level 2:
  • Expert 59 Answers
  • Posted on Mar 31, 2009
millstones
Expert
Level 2:
Answers
59
Questions
Helped
106550
Points
171
E0020 is to do with there not being enough toner in the developer unit.
Firstly it may be a good idea to check/change to toner cartridge.
Switch off and disconnect from mains for the next bit.....
If ok remove the developer roller, cover is above the manual tray on the right hand side then once inside dev unit has connectors at either side, check they are properly seated. If you need to remove the dev there are several black screws around a metal plate all need removing. The roller should be black with toner. May need replacing depending on age and usage of copier.
2 Related Answers
raamasai
veranki srimannarayana
  • 54 Answers
  • Posted on Aug 03, 2008
SOURCE: e000020-0010
reinstall the toner. go to service mode select COPIER>FUNCTION>INSTALL>TONER-S>START>OK
Anonymous
  • 168 Answers
  • Posted on Aug 25, 2009
SOURCE: E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
