SOURCE: I have Windows 7 and just installed PrintMaster
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Testimonial: "Thanks for your help. The regional setting fixed the problem. Great holidays to you. Marc"
SOURCE: Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
SOURCE: I installed Printmaster 2011 platinum
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
SOURCE: PrintMaster 2011 Platinum <3.0.70> encountered
Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
SOURCE: My printmaster platinum 2012 will not open.
Try re-installing software. For more detail on cause. Right click on My Computer > Manage > Event Viewer > Application and check errors / warnings based on source.
