JVC GR-D90U Camcorder Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much is a dew sensor to replace?? - JVC GR-D90U Camcorder
Anonymous
Level 2:
Novelist:
  • Expert 154 Answers
  • Posted on Apr 08, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
154
Questions
0
Helped
58028
Points
327
The dew sensor circuit is near the processing board or circuit component within main board. So the repair will be a standard repair requiring full disassembly for the technician. The average price at www.camerarepairjapan is $165. -James
Where is the dew sensor located inside the Samadhi tv/vice tv
www.fixya.com > Forum > Tags
Jul 13, 2009 - TV is playing Also,the letters D E W are on the screen. Can you Help me? there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape ... 9'' memorex tv/vcr player shows ''DEW'' on screen ...
Apr 3, 2009
SOLVED: "DEW" is on screen and VCR not working
Jun 30, 2007
More results from www.fixya.com
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
5helpful
WHEN I TURN ON THE CAMCORDER IT SAYS DEW
Hi, dew mean its the humidity sensor is on
thats lock all operation/ you can try an air dryer
:/open the loading tray if you can and blow at medium hot ,some hot air in slot for mechanism for few minutes avoid to be to close off the pastic cassing
and leave it rest for a few minutes and try it...
if wont work that is the dew sensor it self defect
hope that will help
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
11helpful
3answers
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Dew Alarm
Many times dew sensor stops giving moisture signal if hot air blows in open cassette compartment for 3-4 minutes from distance through hair dryer.
and some times dew sensor needs to be replaced to stop giving dew signal.
Dew warning message
Dew sensor is defective and you need to replace it to fix the problem.
Video camera won't operate
One of three things is happening here.
1) There is actually dew inside the machine. Try blowing air onto the unit for a while to "dry it out".
2) The dew sensor has failed and needs to be replaced.
3) The solder connections to the dew sensor are marginal which is providing a false reading.
Since this is a camera, getting access to the sensor is not easy. I would bring in the camera for service. If the sensor is bad, the replacement will be around $15. Add in the local labor charge for the complete repair cost.
Dan
Apr 11, 2008 • Cameras
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
4answers
Jvc dew sensor
Just switch the camera on and leave it like that for about 1 hr.. It will clear automatically!
Top JVC Video Cameras Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
