VistaQuest HS-500x Scanner Logo
A
Anonymous Posted on Aug 21, 2013
U56 code - VistaQuest HS-500x Scanner
Laptop battery light flashing orange green
You can find a User Manual here: http://www.asus.com/Notebooks_Ultrabooks/U56E/#support_Download_30 For a explanation on the Battery issue. It sound like it's charging? As for the slowing down, If you don't do regular maintenance , your computer will slow. Also the more programs that Start up at boot will slow it down. If your Internet Browser is slowing down that another problem. There are many freeware programs to clean your Machine. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools, the cleaner and registry will remove junk and free up HDD space. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs to speedup starts and running. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Here are more tips: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332
Clear user password in asus laptop u56e
Boot to the BIOS, in setup clear BIOS password.
1helpful
Need to recover from diski
Have you tried choosing the option to start normaly?
I need manual for ASUS U56E laptop
See the Asus U56E manual on the Asustek Support web site and also the FAQ page for help information.
Please note that this site (fixya.com) has nothing to do with the sales or support of ASUS products or those from any other manufacturers - it is solely a self-help site.
ASUS Manuel for model # U56E
contact me i can send you
servicemanualboy@gmail.com
2helpful
Need user manual for U56E. How do I order/obtain?
Hi herb1t...
Go to the following webpage and download your User manual for your Asus U56E...it will be at the bottom of the page...this page also has all your drivers and other softwear, you might want to bookmark it for future references.
Please take time to rate me
http://support.asus.com/download.aspx?SLanguage=en&m=U56E&p=3&s=343&os=30&hashedid=6KBv9FLOCOczEXLJ
1helpful
Where in the world can I find an Asus U56 owners manual...? It's not even on their website... This is ridiculous.
This might be what you are looking for:
http://dlcdnet.asus.com/pub/ASUS/nb/G73Jh/G73Jh_1229-b.pdf
3helpful
2answers
On a Panasonic DMR-EZ48V I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I...
I think it is usb, not sure why that happens though. Panasonic for some very weird reason mixes upper and lower case letters in some of their on screen bits, so you never know for sure.
I know nothing about this stuff but was having a similar problem with not being able to get the dvd recorder to record onto a dvd.
This was after I had set up the camcorder to the set the day before.
I finally went to 'input select' on the remote and changed it until it worked again, just go through each setting until everything is back to normal.
Somehow, it appears as if the dvd recorder got itself set to the camcorder and would not let go of that setting without changing the input select. I have no idea why because I never touched the input select before this, I always controlled everything with the Directv remote. Hope this helps someone.
I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I have to select or scroll...
I ran into this on a Panasonic DMR-EA38V, and have discovered that yes, it is one of the input selected with the input select button. It will select DVD, usb, SD (for SD card), and VHS. Scared me for a minute!
Top VistaQuest Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a VistaQuest Office Equipment and Supply Expert? Answer questions, earn points and help others
