I have a problem with tracert command on my XP. Fo some reason i get Request timeout for all sites: C:\Documents and Settings\anatolyg>tracert -d www.google.com Tracing route to www.l.google.com [209.85.135.147] over a maximum of 30 hops: 1 * * * Request timed out. 2 * * * Request timed out. 3 * * * Request timed out. 4 * * * Request timed out. 5 * * * Request timed out. 6 * * * Request timed out. 7 * * * Request timed out. 8 * * * Request timed out. 9 * * * Request timed out. 10 * * * Request timed out. 11 * * * Request timed out. 12 * * * Request timed out. 13 * * * Request timed out. 14 * * * Request timed out. 15 213 ms 215 ms 215 ms 209.85.135.147 Trace complete. C:\Documents and Settings\anatolyg>
On your home pc you need to check you firewall or you anti virus settings disable both of them if you have both activated thne reboot your home pc and give it a go. its is normaly spy ware or security software that causes a tracert to time out.
I dont think its a problem its a DOS command to trace the route between you ad the host and the site you visit. go here it explains in detail: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/cnet/cnbd_trb_ssis.mspx?mfr=true
well look at how you explained it in the first instance you had no mention of yourself ringing your ISP.............as far as not being able to do the same at home is because you can only do it in DOS........if your running WinXP the DOS command can be bought about by going to run typing CMD....then you can trace whatever your doing while your logged on (at home?)
1. It is DOS command.And it works me at lptop and at work. It is not working on home pc.
I read link you sendhttp://www.microsoft.com/technet/prodtec...
but how this help me?
2. You "don't think its a problem..."
It is problem for me.
I call to my ISP and report problem with particualr service.
ISP asked me to send tracert output...
But i can not...
That is why i post my problem.
1. Well, look nn my first post.
I provided output of command (MEANS i know how to run it from DOS on XP)
(Sure I run it by going to run typing CMD)
2. Fo some reason i get Request timeout for all sites ONLY from Home PC. I tried to Google and did not find anybody else reported such problem.
1. In my first post i provided output of command (means i know how to run it from DOS on XP)
When i connect another P at home to the same network cable i do not see such problem:
U:\>tracert -d www.google.com
Tracing route to www.l.google.com [209.85.135.103]
1 <1 ms <1 ms <1 ms 192.168.50.254
2 59 ms 44 ms 45 ms 213.8.255.155
3 27 ms 45 ms 46 ms 213.8.228.33
6 21 ms 44 ms 51 ms 213.8.205.34
7 39 ms 43 ms 55 ms 192.116.203.38
8 134 ms 86 ms 109 ms 213.8.8.130
9 93 ms 91 ms 111 ms 195.27.252.225
10 122 ms 123 ms 91 ms 195.2.10.158
11 85 ms 101 ms 143 ms 72.14.198.109
12 107 ms 135 ms 103 ms 209.85.249.178
13 99 ms 123 ms 99 ms 209.85.248.248
14 118 ms 206 ms 96 ms 66.249.94.85
15 160 ms 164 ms 183 ms 209.85.253.22
16 118 ms 95 ms 124 ms 209.85.135.103
Trace complete.
U:\>
So it seems to be my XP System problem ...Any ideas what can be wrong?
