Tools & Hardware - Others Logo
dave wilson Posted on Sep 05, 2013
How do I load Ace Hardware Model 2111771? I have Ace heavy duty staples 3/8x10mm
  • dave wilson Sep 05, 2013
    none of those comments address my problem
rebeccaroberts
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 40 Answers
  • Posted on Sep 21, 2013
rebeccaroberts
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
40
Questions
0
Helped
6970
Points
42
Check other online sites
3 Related Answers
kozmikkurt
  • 40 Answers
  • Posted on Mar 14, 2009
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Steve_53
  • 23 Answers
  • Posted on Mar 22, 2009
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Oct 03, 2009
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Top Ace Hardware Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
