When power is turned on screen goes to "SATA Port 0 hdd security code ST320lt020-9yg142" Can you tell me how to fix other than tech.
Ur bios feature may hav been given with security code, so what ever u connect may ask the same thing..first remove the security code n thn try it..!!
SOURCE: asking for password sata port pass
This is a "security" feature, to protect the files on the disk-drive from unauthorized access.
The computer supports "full-disk" encryption of each disk-drive inside your computer.
So, what password did you set when you first initialized this disk-drive?
If you don't know it, there's nothing you can do -- all the files on the disk-drive are _NOT_ accessible to you.
SOURCE: have a acer aspire 5515 notebook laptop it keeps
It sounds like you may need to go into the BIOS and change or disable the password. Alternatively, clear the CMOS.
SOURCE: How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
Cheap solution available at http://www.acersnoop.co.cc
SOURCE: when I turn on my
you go in your bios to remove but your bios is probly locked pull the small main board battery out turn it on and off put battery back in its under one of the panel on the bottom..
