Freezers Logo
glenda smith Posted on Sep 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 8 - Frigidaire Freezers
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 11, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1495608
Points
5908
Good Afternoon Glenda, thank you for your inquiry!
Is it possible that the error code is missing characters? According to my research 8 is not a valid error code. The number 8 is more like a temperature setting, however to be certain, let's try resetting the appliance. It is important to wait roughly ten minutes and then turn the unit on. Set the correct temperature and please allow 24 hours for the temperature to stabilize. The error code should clear and the unit resume to normal operations. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Best regards!
Midea MRS26D5AST Side-by-Side Refrigerator. I have code ep, how to fix please?
Question edited for clarity, full 'make model (what it is)' and correct spelling of make 'Media' to Midea.
Question moved from Cars and Trucks category.
Ice Maker Probe Error
I have a Midea side by side fridge that's about 2 years old.
JustAnswer
https://www.justanswer.com > Appliance Repair
Jul 26, 2023 - The EP error indicates a failure with the temperature sensor or the control board. This would keep the ice maker from activating. Here's the ...
1 answer · Top answer: Greetings and welcome to justanswer, an independent paid question and answer platform. Just ...
Error Codes - Midea MRS26D5AST User Manual [Page 36]
ManualsLib
https://www.manualslib.com > ... > User manual
Midea MRS26D5AST Manual Online: Error Codes. If an error code is displayed on the control panel, contact your place of purchase or Insignia customer service ...
E3, E4, E5, E7, Eb, Ed, EF, EP, EU, F9,Fb, Fd - Midea
midea.es
https://www.midea.es > uploads > 2020/10 > E3-...
PDF Error code is displayed on main PCB and user interface. 3 Possible causes. ? Temperature sensor or pressure sensor are not connected properly or malfunctioned.
3 pages
https://www.google.com/search?q=Midea+MRS26D5AST+error+code+ep
2answers
True T-49F 55? 2 Door Solid Reach In Freezer. How to solve error code E1 on freezer Tru T49f?
Question edited for clarity.
Question moved to maker category.
Thermostat Probe Error
E1 error on a true freezer. True Freezer, 5yrs. Just
JustAnswer
Mar 6, 2022 - Ok. The E1 error code indicates a thermostat probe failure.
1 answer · Top answer: Hi, welcome to JustAnswer. My name is***** am a ticketed HVAC and refrigeration technician with ...
True Refrigeration Troubleshooting
Parts Town
https://www.partstown.com > resource-center > guides
P1 Alarm/ E1 Code. What does it mean? - This indicates a thermostat probe failure. "P1" displays on units with Dixell electronic controls. "E1" .
2answers
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
1helpful
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
2helpful
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Error code FF on LFUH2157lm2
Follow through with google punch in code and model.
4helpful
3answers
Samsung RSA1WTMH i just blew my fusebox and my fridge freezer just flashing 1 led light
hope the following helps you, I had a similar problem with my RSH1 and it took me a few hours searching online before I found the following.
"Hi, I have it on good authority that this is the system check for Samsungs (RS21, SRS20, etc) during normal operation, is to hold the top two buttons down, just until display flashes - this will reset the electronics.
Secondly, if the top two buttons are held down for longer (8 seconds) the display goes blank and will show any error messages in the form of DASHES
I have experimented with unplugging air or frost probes - and the error code you get -on a blank screen is different parts of the last digit lighting up.
Example: when i disconnect the fridge air-probe, shut both doors, hold down top buttons around display - The SIDE of the last "8" digit lights up ! ...strange but true.
But, I need to know what it means when the BOTTOM of the "8" digit lights up"
I am still trying to find a list of the error codes the lines refer to but so far my unit is working fine.
Angus
Sep 21, 2010 • Freezers
Top Frigidaire Freezers Experts
jdthefixer
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
