Computers & Internet Logo
Amanda Posted on Sep 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not log on with my code - Computers & Internet
poepad
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 69 Answers
  • Posted on Oct 19, 2013
poepad
Expert
Level 2:
Cheetah:
Answers
69
Questions
0
Helped
15681
Points
102
Need more details please
1helpful
Engine Code P0171 Logged
If Short term # is high while underway, but normal while idling, you could have a scewed maf signal. Sometimes cleaning maf with carb cleaner helps. If no intake leaks are found, and fuel pressure and volume are ok, it could be maf sensor.
1helpful
3answers
How do I access my gmail account on another computer? I have no problem accessing it on my Ipad?!?
Just open your browser and go to www.gmail.com .
If you see his e-mail, log out. You must then log yourself in.
Don't forget to log yourself out when you're done.
2answers
States there is a problem and I can not log in
Log in to what/where? You obviously managed to log in to FixYa?
Need help with log in code
Log in to what/where? You obviously managed to log in to FixYa.
Or are you asking about writing some code to allow logging in? If so, for what system?
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
2helpful
I CANT LOG IN AND IT ASKD ME TO TYPE IN A CODE THAT SHOWS UP SO IT WILL LET ME LOG IN AND IS STILL NOT WORKN IT KEEPS GIVING ME DIFFERENT CODES TO USE AS PASSWORDS I KEEP TYPING THEM AND WONT ALLOW ME TO...
I have to assume you mean logging into a web site of some kind.
The 'code' that you type in IS NOT THE PROBLEM. That is only to prove you are human and not a computer trying to access the site.
The Problem is the log in info you are using. The Log In NAME and PASSWORD need to be correct. The extra funny looking info [code] is not the log in info, just human proof.
You may need to follow a link for 'Forgotten Password' or 'Log in name' to help you log in.
Hope this helps.
15helpful
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Log user in and out
Log out would be *36
Log in default code is:
*35*N# (where N is your extension number)
But those codes can be changed, so they may not work.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
