SOURCE: add password to Wireless G
a #, address was provided so you can set up your belkin utility's thru your internet browser( just type the address provided into your browser then it will ask for a security code( by default its blank just hit submit) then you should be able to control your belkin settings. don't forget to apply changes after making a change in the settings.
SOURCE: Mac Office X Excel doesn't run. Get an "Not enough memory to open Microsoft Excel" error
format it then install it again or reinstall it..
SOURCE: Already asked and paid for
Software keys are part of the copywrite protection incorporated into software to ensure legitimate distribution. People here can not legally give you a key that you should have received when you bought the software or should have been included with a new computer. You can try searching online for illegitimate means of getting a key or you can go back to the source you got the items from and get a key from them. For example, most Mac sales outlet support staffs can get you a key if the software was included as part of a Mac purchase.
SOURCE: I need a product key code for microsoft office for MAC 2011?
You should contact Microsoft directly. Using legitimate product keys will also keep you from having update or activation issues in the future.
SOURCE: Hi!! How are u? My
Microsoft has stopped providing XP users with security updates, forcing them to either upgrade to another, newer operating system, or gamble with their safety. While the latest usage figures show that a large portion of users are moving away from XP, there's still a sizable number of users who aren't -- or can't.
If you're an XP user, or know some XP users, there's a trick which makes it possible to receive security updates for the aging OS for another five years -- right up until April 2019.
The workaround makes use of updates for Windows Embedded Industry (formerly known as Windows Embedded POSReady). This is based on Windows XP Service Pack 3, and the security updates which are being released for it are essentially the same ones Microsoft would have pushed out for XP, if it was still doing so.
You can't simply install the updates -- that would be too easy -- and you'll receive a version mismatch error if you try. But a simple registry tweak is enough to fix that.
Create a text document, and call it XP.reg. You'll need to make sure .reg is the proper extension -- so not "XP.reg.txt". If it's not showing up as a registry file, open any folder, go to Tools > Folder Options, select View and uncheck 'Show hidden files and folders'. That should fix the problem.
Right-click the file, and select Edit. Paste in the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
