It seems you're encountering the "No Command" error on your Leelbox Q1. Let's troubleshoot this issue and explore potential solutions:
Recovery Mode:
When you see the "No Command" screen, it usually means your device is in recovery mode.
Try the following steps:
Press and hold the Power button along with the Home button (or Volume Down button, depending on your device).
Keep holding both buttons until you see a menu.
From there, you can select options like "Reboot system now" or "Wipe data/factory reset."
If this works, your device should boot normally.
Boot Loop with No Command Error:
If your device is stuck in a boot loop with the "No Command" error, try these solutions:
Press and Hold Power+Home Keys:
Depending on your phone manufacturer, this combination might open recovery mode and allow you to fix the issue.
Check Recovery Partition:
Ensure that your device has a functional recovery partition.
Some devices ship without a recovery partition, which could cause this error.
Serial Port Debugging (Advanced):
If you're comfortable with hardware debugging, consider accessing the serial port on your Leelbox Q1.
The board appears to have an accessible serial port (the four holes near the SD card slot).
Obtain a TTL-to-USB adapter and connect it to the serial port.
Log the boot process to identify any issues during startup.
Armbian does not boot from an SD card intentionally, so you'll need to follow specific installation procedures.
Multitool and Armbian images:
You mentioned using the multitool image and various Armbian images.
Ensure that you're following the correct installation procedures for your specific Leelbox Q1 model.
The LED should blink when the multitool boots, and you can access it via SSH even if there's no display output.
Remember, debugging hardware issues can be complex, so proceed cautiously. If you're unsure, seek professional assistance.
How To Fix Android "No Command" Error - A Definitive Guide (gtricks.com)
Leelbox Q1, rk3229 box not booting - Rockchip CPU Boxes - Armbian Community Forums
