Kyocera Mita KM-2050 Printer Logo
shahbaz gul Posted on Sep 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C6000 code - Kyocera Mita KM-2050 Printer
Unknown Person
Level 2:
Sergeant:
  • Expert 245 Answers
  • Posted on Sep 25, 2013
Unknown Person
Expert
Level 2:
Sergeant:
Answers
245
Questions
0
Helped
48447
Points
662
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
My Konica Minolta Bizhub Press C6000 Pro. How to remove error code C2402 in Bizhub Press C6000 Pro please?
Question edited for clarity and toss in some CAPS.
Question moved to category.
Error Codes > Konica-Minolta > bizhub 500 > Code C-2402
Printcopy.info https://printcopy.info > code=C-2402
Code: C-2402; Description: Erase lamp (EL) connector slip-off abnormality. - When EL turns ON before starting an initial charging, EL abnormality has been ...
Missing: press ‎C6000 ‎Pro.
Bizhub PRESS C6000 error codes
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Aug 7, 2013 - 1. Check the connection between the rear side connector of the fusing unit and the main body side connector, and repair it if any abnormality.
Hola tengo una minolta c6000 que sale el codigo c 2244
Wrong code for machine, but good for Kyocera!
Code: C2244 · Description: Drum motor Y sub sensor error. No signal is input to the sensor for 1.5 s continuously. · Causes: Poor contact in the connector ...
https://www.google.com/search?q=konica+minolta+c6000+error+code+list%2C+C2244
1helpful
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
What is c2704 in konica minolta c6000
I think that is the code for the black charger unit. It might be the charger itself or a board problem. Make sure the black charger is seated correctly.
Kyocera FS1118, error code C6000,how do I resolve this?
C6000 code is a fuser that failed to warmup.
Broken fuser heater lamp wire
The fuser temperature does not rise
after the fuser heater lamp has been
turned on.
Tttt
To resolve you will need a tech to replace parts in the fuser assembly.
2helpful
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Code d'erreur C3505
Fusing error have tech look at and reset
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C-6402 error code in C6000
no such code in the service manual
22helpful
5answers
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Top Kyocera Mita Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
