No need of any special solution. I had the same issue/error message with my DCR-DVD01 - Sony camcoder which is now 9 years old.
What i did is the following? (weird steps):
1. Turn on the sony camcoder - while connected to wall power
source.
2. Keep a heavy cloth on top of your dinner table or kitchen island.
3. Hold the camcoder facing up in the regular way as you try to
record a new video.
4. Hold on the front of the camcoder & at the back and gently tap
on the heavy cloth (as if you are going to smash it & break it).
5. Do this 3 times.
6. Shut down the camcoder.
7. Restart the camcoder after 3-5 seconds.
Thats it.
This worked for me.
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
E61
Insufficient heating during washing
Usually a heater failure but possibly the thermostat or NTC temperature sensor or wiring to either.
