Haier HWD1000 Logo
S
SARA Posted on Oct 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ERROR LOCK CODE: LOC - Haier HWD1000
Denny Giesel
Level 3:
Master:
  • Master 818 Answers
  • Posted on Oct 12, 2013
Denny Giesel
Master
Level 3:
Master:
Answers
818
Questions
0
Helped
158170
Points
2428
Push temp button #9 and hold for three seconds LOC should clear. press the same button and it will lock controls again-but I don't know why you'd want to do that-cheersDenny
Maytag, front load washer, model is below. It's 1 month old. I've loaded detergent and clothes. Press start and error code of Loc comes up?? I accidently bumped screen when reaching for detergent, not sure...
Possible Solutions
There is no Error - Control Lock is activated
If the control lock has been activated, the control will not function. If you try to push buttons, you may see the code "LoC" or "LC" (depending on your model). This is a reminder that you have set the control lock, and need to de-activate it to allow the washer controls to function.
Activating the Control Lock: Touch and hold for 3 seconds to lock the controls to avoid unwanted changes or operation. For each second CONTROL LOCK is held down, the display will count down one second: you will see "3," then "2," then "1" then "LC" or "LoC". You may still touch START to pause the cycle, or touch POWER to turn off the washer.
De-Activating the Control Lock: Touch and hold 3 seconds again to de-activate the Control Lock.
See your Owner's Manual for more information on setting the Control Lock.
If you would like to download or view product literature for your appliance, please visit our Manuals and Literature page.
1helpful
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
1helpful
2answers
ERROR CODE LOC
I'm not sure what just happened here-I posted and my answer went away! Push and hold temp button for 3 seconds and LOC should clear-if you want to lock controls again repeat-cheers Denny
2answers
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
6helpful
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
12helpful
LOC Error Code on Kenmore Washer model 417.44082400
Hi.The control is in a "LOCK" feature. Press and hold the Options and Select at the same time until the "LOC" led goes off to take the control out of "LOCK" or to put it into a control "LOCK".
NOTE_ If this standard procedure doesn't release the lock, this will indicate that the main control module is damaged.
10helpful
Error code LOC
12helpful
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
112helpful
7answers
Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Jan 01, 2009 • Dryers
Top Haier Washing Machines Experts
Paul Carew
vince
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
