Creative Labs Zen Neeon MP3 Player Logo
Posted on Sep 26, 2007
My Computer Won't Read It!!!
Okay, so every time I go to turn my MP3 Player on it comes uo with the Creative logo and then the dead battery signal. But when I plug it into the computer it can't be read and so it doesn't charge and I'm dying without my music!! I NEED IT! Can anyone help?? Would be greatly appriciated =[
  • Anonymous Nov 09, 2007
    yeah got the same problem, i plug it in and its not recognised, even though it runs of universal storage drivers
  • revon pereira Dec 19, 2007
    i hae a similar issue with my zen neeon...only it wont come on at all..
    When i attach it to my pc it says "usb device not recodnized" and it will not com on even whe i removed itout at tried to put it on..
    it worked fine in the mornin
    can some one who already solved this issue pls help!!!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Dec 24, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
9963
Points
57
These symptoms points to a bad hardrive. Replace the hardisk and reload the latest firmware.
If your out of warranty with your Neeon, open it up. Loosen the 2 screws at the bottom of the player and remove it. Then carefully pry open the back plate using a small flat screw driver and remove the battery (it has a mini connecter on the top left, inline with the USB connector).
Remove the front cover. You'll find the hardisk on top of the board below the LCD. Remove it carefully from the connector. on its right side.
If you got a new HD, replace the old one and reassemble your Neeon.
Next download the latest Neeon Firmware Upgrade here:
http://sg.creative.com/support/downloads/download2.asp?MainCategory=213&Product=12214&dlcentric=9534&Product_Name=ZEN+Neeon+5GB%2F+6GB&OSName=Windows+XP
Firmware above is for Windows XP. You can download a version of the Firmware at Creative site in your region for your specific OS requirement...
Before
To install this firmware upgrade:
1. Press and hold the Play button while connecting your player to your computer's USB port.
2. Continue to hold the Play button for 10 seconds after connecting your player to your computer.
3. Release the Play button when the Find New Hardware dialog box appears on the screen.
4. Follow the instructions on the screen to install recovery drivers for your player.
5. Download the ZenNeeon_PCFW_LF_1_011_FM.exe file into your local hard disk.
6. Double-click the firmware upgrade file and follow the instructions on the screen.
I found the above instructions with other Neeon's forum here:
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=176728
You'll have the option to format and reload firmware. Choose that option. Wait for the upgrade progress to finish.
When it's done, your player will connect and recognized by your computer. If it shows in MY COMPUTER as removable drive, then your in luck!
Proceed by drag and drop method of transfering your music files or using the CREATIVE MEDIA SOURCE ORGANIZER.
I'm currently looking for a way to hack the Neeons Hard Drive and replace it with a CF card just like what I did with my Zen Micro. Unfortunately the first CF card I bought (1 Gbyte) did not work on the Neeon, the XP wont recognize the player.
But I'm not giving up, I had to find a better replacement that match the compatibility requirements of the Neeon. I'll try different brands and speed. The CF card is much more robust and shock free. It reads faster with no hang-ups.
I'll post my results in the future if I succeed.
Top Creative Labs Audio Players & Recorders Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
