Indesit 24 in. D61 Free-standing Dishwasher Logo
s
sharon-linton Posted on Oct 31, 2013
Error code F02 - Indesit 24 in. D61 Free-standing Dishwasher
tip
F02 Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
If the pump motor or impeller becomes damaged and does not pump at the correct volume, the error code will not clear. If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 • Washing Machines
tip
F02 Error Code
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
on Dec 09, 2009 • Washing Machines
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
My whirlpool duet washer had a F02 code now it won't pump water
What does F02 code on duet washer mean?
3helpful
2answers
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
2helpful
It quits on the drain cycle and a error code f02 appears
Error F02 code means Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
1helpful
F02 code flashes and stops rinse cycle
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Top Indesit Dishwashers Experts
Paul Bade
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
