Hardware & Accessories Logo
A
Anonymous Posted on Nov 04, 2013
How to replace the spring for the on tripper on a wh21 electric hot water heater timer
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on May 14, 2009
SOURCE: Intermatic electric water heater timer only gives
Try turning your thermostat up 20 degrees. That will make hotter water, requiring more cold to mix so you'll use less hot water for the shower. If that helps but you'd like it longer, increase the temperature in 10 degree increments until you reach a temperature that works.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jun 26, 2009
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Joel Friedenberg
  • 1114 Answers
  • Posted on Aug 15, 2009
SOURCE: The Trippers on my Paragon Electric timer are
The following Web Site lists tripper pins for Paragon timers. I don't know if your model is listed, but give it a try.
I hope this helps!
http://www.icca.invensys.com/paragon/parts_accessories.htm
Anonymous
  • 52 Answers
  • Posted on Dec 30, 2009
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Anonymous
  • 565 Answers
  • Posted on Jan 02, 2010
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
Top Intermatic Hardware & Accessories Experts
jdthefixer
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
