This is from the service manual and should help you
determine if you need to call in for service. If is in warranty I would
anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
HI I WILL FAC E A PROBLEM in hp 4345mfp error 58.04 plz give me resole solution
the fuser unit probabaly need replacement Good Luck
on page 191.
hp color laserjet cp2025dn printer tray track has come loose. I need to reattach this arm on the printer in order to have the printer tray close.
