Bosch Axxis+ WFR 2460 Front Load Washer Logo
B
Bosch Wannabe fixer upper Posted on Nov 27, 2013
Error 16 My washer would not fill with water when I started a wash cycle, the drain pump would kick in and it would lock the door. It would not open the door when I paused the cycle and returned a message of "cannot open door water level too high". I drained the water from the machine blew out the tubes for both the water level sensor (part 182233) and the analog pressure switch (part 182238 and it still didn't work. I put it in test mode and ran test 8 & 9. I don't understand most of it but the value of the analogue pressure sensor said "n139" - I can't actually remember but I know it was not "n000". I ended up replacing both the water level sensor and the analogue pressure switching hoping that one of those were the problem. NOPE, the washer still won't fill with water - when I hit start the message "detergent dispensing" appears, but no water, and the drain pump kicks in as usual. Now when I enter into Test mode, it automatically gives me the message Error 16. Help!
Felixberto Villamil
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 27, 2013
Felixberto Villamil
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
743
Points
11
Check your solenoid valves if the coils are healthy.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jun 22, 2007
SOURCE: Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Anonymous
  • Posted on Dec 07, 2008
SOURCE: WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
prem mathew
  • 662 Answers
  • Posted on Jun 15, 2010
SOURCE: Error 03 not draining or going to spin cycle. Tub
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
w_kratzer585
  • 14 Answers
  • Posted on Jan 31, 2011
SOURCE: Error code E04? Doesn't drain or spin. Machine
SEIMENS FRONT LOADER ULTRA SENSE DRAINING PROBLEM
On my SEIMENS washer, which is about the same as BOSCH, the drain problem seems to be usually a small sock jammed in the intake of the drain pump, or possibly in a hose before the pump. I found a quarter and a couple of staples in the attached settlement area where junk settles to avoid jamming the pump. Also a lot of dirt.
On the lower front under the door, while facing the washer, is a round plate with a little hole in it. Put something sturdy, a little bigger than a toothpick in there, and rotate the plate about a 16th of a turn, maybe a little more, and it comes off.
Take duct tape or similar and tape up the edges of the hole and a nearly vertical bar in the hold on the left side, because the edges will cut your hand, like they did mine.
Inside the hole you will see a black turn knob inside. Turn it left very slowly, only after you figure out where the water will go, probably a small bucket or two of it. I used a 4" funnel which got most of it, I think, funneling into the bucket. Maybe you can be more creative, but it is what was at hand. Still got water on the floor out of the garage into the street. Turn left slowly, so it doesn't dump water outside of the funnel. You will see the water is brown, silt, dirt and stuff.
If you get a lot of water out, that means the blockage is probably at the pump. If you don't get water out, the blockage is probably in the hoses from the washer, which means you need to undo hose clamps going into the pump and clear the blockage. That is harder.
Most likely it is something in the pump area itself.
After most or all of the water is gone, and it doesn't seem to unscrew any more, tug on it and it will come out exposing the pump and probably the sock.
Remove the sock, and check the pump impellors to make sure they are intact. If gone, that means a new impellor and probably a pump. Then move the impellor, it should click as it moves and stop. If it does, you have found the problem. Sock blocking the outlet.
Carefully clean out the **** inside the pump settlement area. If you leave any of the sandy gritty clumpy stuff it can ruin your pump. Also clean the plastic thingy you pulled out, and make sure the threads and sealing surfaces are clean there too.
Then screw it back in firmly, and start the washer, without clothes. I would just fill it up, starting the cycle, until it starts to agitate, then go to the drain position
With luck, it will now drain. .
This will save you a service call for something easy to fix yourself.
Anonymous
  • Posted on Jun 02, 2011
SOURCE: bosch 2460uc washing machine give water tap closed
Water tab goes off all the time, get rid of machine, don't buy Bosch
Top Bosch Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
