Toshiba e-Studio 232 Black and White Copier Logo
A
Anonymous Posted on Dec 07, 2013
Error code f100 - Toshiba e-Studio 232 Black and White Copier
Error code on toshiba laptop F3-f100-003
No doubt that the hard drive has serious problem, You need to replace the hard drive ... Then reinstall the operating system on the new drive using the disc you have.
F3-f100-003 error code what does it mean?
The new HDD apparently has no OS. what is what the msg says.
boot to Bootable media with to install a NEW OS. or boot to your Recovery Media. and let it restore to Factory.
if this does not help - then provide more info.
7helpful
3answers
How do i fix error code f100 1 for toshiba e studio 2040c?
F101 HDD failure,,08-9030..or update the firmware version.if not okey replace the HDD.
F3-F100-0010
http://www.windowserrorhelps.com/error-f3-f100-0010-fix-toshiba-error-f3-f100-0010-the-simplest-way/
This website explains it well, along with a few options to fix it. Uses some computer jargon but is fairly easy to understand.
2helpful
On start up of my Toshiba Satellite L505-S5990 laptop I get the error code F3-F100-0003. What does that mean? How do I fix?
Hi ilikepie2,
Unfortunately Error F3-F100-0003 means that the hard disk has failed. You need to replace the hard drive of your computer. If you can get someone (local tech) to check if they can still recover the files on it, it would be better.
Thanks for using Fixya.
8helpful
3answers
Service Required Error code F100. What do we need to do?
F100 indicatest HDD failure...
The best way to solve it is to replace a new HDD & update firmware~~~
I have troubles with a printer eSutudio4511. Code
f100 is a hard drive formatting error
[F100] HDD format error
(1) Check if the HDD is mounted.
(2) Check if the specified HDD is mounted.
(3) Check if the connector pins of the HDD are bent.
(4) Check if the connectors CN116, CN132 on the SYS board is disconnected.
(5) Replace the harness.
(6) Format the HDD. (Key in "2" at 08-690.)
(7) Replace the HDD.
(8) Replace the SYS board.
step 6 is turning the copier on while holding 0 and 8 til it beeps type 690 and hit start, this will format your hard drive, more than likely it is bad physically but you may get lucky
Top Toshiba Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
