GE JKP86 Electric Double Oven Logo
V
Virginia chapman Posted on Dec 07, 2013
Ge built in microwave and oven. Jkp86
Microwave table does not rotate
2 Related Answers
TheRepairGur
Chris Z
  • 27 Answers
  • Posted on Jan 26, 2009
SOURCE: GE Microwave Model JKP85 Plate does not rotate
Usually this is a bad turntable drive motor in the floor of the microwave but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru ----- www.repairclinic.com
Click here For: GE-Microwave-Parts
Anonymous
  • 443 Answers
  • Posted on Jan 27, 2010
SOURCE: i have a ge jkp86 electric oven the oven will not
First thing that comes to mind is to make sure you are getting the correct voltage to the oven, you need 220 / 240 volts, check your breakers, fuses ,etc.
It is possable for the microwave oven to operate even if the power supplied to the oven is only 110 volts, but that low of voltage is not enough to power up the ovens heating elements.
If all seems well there, then maybe the oven element has failed / shorted ?
Good luck !
Top GE Ovens Experts
Paul Bade
Paul Carew
Are you a GE Oven Expert? Answer questions, earn points and help others
