Ultra Products (ULT33046) UPS System Logo
P
Paul Pendleton Posted on Dec 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows USB Driver
Windows 7 x64 or Windows 8 x64
Reuel Teoh
Level 2:
Champion:
  • Expert 411 Answers
  • Posted on Dec 18, 2013
Reuel Teoh
Expert
Level 2:
Champion:
Answers
411
Questions
Helped
116319
Points
490
64bits drivers not available.
Buy a UPS with compatible 64bits drivers e.g. APC
Testimonial: "The latest driver for the Ultra Products 33046 UPSMON Plus software is ~v2.85. It is compatible with Windows 7 x64."
  • Reuel Teoh Dec 19, 2013
    Sorry, I still have two UPS using UPSMON 2.7 that cannot support x64
3helpful
3answers
Add driver for window 7
Microsoft Windows Vista and Windows 7 does not include native drivers for the Del True Mobile 1450 USB Wireless adapter and there will be no 1450 USB Wireless adapter drivers available from Dell that are compatible with the Windows Vista or Winds 7 Operating System.
There will be no support for the Dell True Mobile 1450 USB Wireless adapter in Windows Vista or Windows 7.
For 1450 USB Wireless adapter drivers for Windows XP 32bit Click Here.
1helpful
SIIG (JU-P50212) USB 2.0 Network Adapter
If you did a fresh install of Windows 7, make sure you install Windows 7 SP1.
A lot of Windows 7 drivers were not included in the original release.
http://windows.microsoft.com/installwindows7sp1
The manufacturer does not list a specific driver for this card( although it does list it as being Windows 7 compatable) so likely you will find it by updating Windows 7.
http://www.siig.com/hi-speed-usb-5-port-pci.html
Ihave a windows 7 iwant to install usb driver plz give usb driver
Usb does not need a driver the USB controller will but windows 7 should automatically install it. Also try to use the CD of the Hardware your installing.
1helpful
2answers
Driver for windows 7
According to the Hewlett-Packard support website, DOWNLOAD the DeskJet 3600 Series driver for Windows 7. It is equal to the USB driver for the DeskJet 3325. At the present time, the Deskjet 3600 Driver is available thru WINDOWS UPDATE ONLY. Enable WINDOWS UPDATE on your Windows 7 PC and manually download this driver.
At this time, a full feature Windows 7 driver solution is not available for your product.However, a compatible print driver solution for your product is included with the Windows 7 operating system. There is no need to download any additional software. Follow the steps in this document to identify the print driver that is compatible with the product, install the driver, and then configure it in Windows 7. When this driver is installed, you can use the basic functions of the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif), and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next.
  9. NOTE: If your HP product is available through Windows Update, click the Windows Update button to select additional print drivers. You must connect to the Internet before using Windows Update.
  10. In the Printer name text box, type the product name and then click Next. The print driver starts the installation process.
  11. NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.When the installation is complete, a message displays on the computer stating that the product was added successfully.
  12. In the message window, click Finished.
  13. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  14. Click Close (c01900743.gif) to close the window.
Follow these steps to configure the installed driver.
  1. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  2. Click the Ports tab.
  3. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  4. NOTE: If there is more than one USB/DOT4 port available, select the USB/DOT4 port with the highest port number. To see the full port name, widen the ports row in the Properties dialog box by placing the cursor over the vertical line between Port and Description, and then click and hold the mouse button. Move the mouse to the right until the port name is visible.
  5. Click OK.
I installed windows 7, nw my USB camera driver is ...
camera criver software is for windows vista 32 bit only. We are still developing the sofware for Windows 7 operating system. You can check the software availabilit by clicking the link here.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5helpful
Windows 7 driver for usb camera on msi vr610
all drivers are foudn here
http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1352
there may not be a Windows 7 specific driver. try using the windows vista driver. many times when there is no win 7 the vista one will work. win 7 realy is the full version of vista anyway
16helpful
2answers
2helpful
2answers
Need USB drivers for Huawei Quidway WA1003A Router.
Try the following link: http://www.calcuttatelephones.com/dataoneinstall/mdm05.html
The USB driver proposed for download might be compatible with Windows 7.
3helpful
2answers
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
66helpful
12answers
USB Driver for Starcom : Model- UT300R2U ADSL2+ Modem
Hi,This modem has only two ports - 1 Ethernet and 1 USB. I want to connect the USB Port to my PC. I am unable to get a suitable driver. Please help me in finding from which site the driver could be downloade.
Top Ultra Computers & Internet Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
