Minolta bizhub 200 All-In-One Printer Logo
A
Anonymous Posted on Dec 15, 2013
Devloper reset code
Konica buzz 164
Norman Weimar
Level 3:
  • Minolta Master 7,080 Answers
  • Posted on Feb 04, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7080
Questions
Helped
1997807
Points
12012
Has the developer been replaced? If not reset code for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counter with out replacing the require item the copier will adjust certain voltages to certain items such as the drum and developer system as those there are new because you reset the counters when in fact he developer is old and so mite be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared and was the required F8 checked run?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
