Hold auto and track up for 3 seconds. use remote to enter *KCAR* hold track up for 3 seconds, it will be accepted
Security Code is not accepted.
The code number is incorrect. Please enter code which is printed on your radio passport.
First coding doesn't function.
The code was not entered immediately after first start-up. Put the equipment back into the original operating conditions by pressing RESET key. Then enter the code which is printed on your radio passport.
There are a number of ways to "RESET" (which may or may not solve the problem - proceed at your own risk).
From a G search on the subject...
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
when finish all the procedure, is necessary to press "TRACK UP BUTTON" for 3 seconds.. and youre done.
hooking up the kdc-328 and i need the 4 digit security code.
yes
sercurity code needed to operate
I also need the security code for my Kenwood KDC-MP628. PLEEEEZE HELP!!!!!!
al encender el estereo me pide un codigo de 4 digitos, como el estereo me fue obsequiado no tengo los numeros
I HAVE A KENWOOD KDC-MP7028 AND I NEED SECURITY CODE
I have a 2001 honda oddysee van. I reset my radio to enter my code, but the radio code has zero's in it. how do i enter zero's? all the number i see is the nuber 1 - 6 on the radio
i just bought a 1994 F150 and the dealership i bought it from put a new battery in it and ever since then the part of the radio where the cloke is reads BAD i pulled the radio out and there was a code on one of the wires i think it was 2584 but how do i enter it in if there is no 8 on the radio?
security code 4 kdc 3280
I BOUGHT A CD PLAYER.
BUT I NEED UPTAIN THE CODE
