Electrical Supplies Logo
A
Anonymous Posted on Jan 03, 2014
Error code A60 - GE Electrical Supplies
Wifi conneection
like my phone screen i cracked and i can use it and everything but i have these annoying black vertical lines its a at&t phone by the way
Siemens a60 unlock code
If you want to unlock your Siemens A60 mobile phone from the network lock,you can get network unlock code from Theunlockspot.com at reasonable price.Here they ask you to specify the country name,current network provider and IMEI number of your mobile phone.After specifying these details,they deliver an unlock code through email.Then you can unlock it using code by following the instructions given for your mobile phone from that site itself.
Jul 16, 2013 • Cell Phones
When i on my latop after 1 min or in starting give error and screen become green and restart why ? please help e my laptop is toshiba satellite a60. pleease help me and please reply me ons stylo...
Check your memory. If you have a faulty or substandard RAM chip, this is a likely cause. Also there may be an error on the hard drive. Run CHKDSK/F as soon as you get it to boot and save all of your data!!!!
E18 error
Lens errors (on older Canons this is known as an E18 error) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Camera Will not turn on
Pull the battery(s) out, pull the memory card out. With a compressed air can (for cleaning computers) blow out the battery compartment and very carefully clean out the memory card slot... don't bend any tabs or pins..
Also blow out any other openings around the batt compartment door/latch area.
reinstall batts and card.... any luck? Any error code on the screen?
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Display Driver problem
You need to uninstall your ATI display driver and then download and reinstall the driver from here :
http://www.drivercabinet.com/toshiba-satellite-a60-driver-windows-xp-downloads/
Canon powershot A60. When the camera is turned on there is no image won't take shots, has a number on screen E18 and shuts down after a few seconds. Mike
E18 is an error code from self diagnostic system of the camera.if there is a malfunction in the lense assembly or the focus assembly then this error code appears. You have t show it at a repair shop.
Jul 17, 2008 • Cameras
2helpful
2answers
Unlock phone
Siemens A60 can not be unlocked by code. It is necessary to load bootcore before entering unlock code to it and entering unlock code manually is not possible in A60. There is technic named "test point unlocking" for the same. For that needs some skill and software named SST( Siemens Service Tools). It is advisable to unlock it at technician's shop. If he need test-point picture then mail me. I will send it to you.
Jan 09, 2008 • Siemens A60
Top GE Electrical Supplies Experts
vince
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
