One For All URC-3021 Remote Control Logo
A
Anonymous Posted on Jan 04, 2014
Sharp codes - One For All URC-3021 Remote Control
Can anyone help me fix E1-00 on Sharp AR copier?
Sure, but model numbers are important in questions like this. Generic help here.
Error Codes > Sharp > ARM207 > Code E1-00
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E1-00
Code: E1-00 · Description: IMC PWB communication trouble · Causes: IMC PWB-MCU PWB harness abnormality MCU PWB connector disconnection IMC PWB ROM defect/data ...
Sharp AR-M207 Service Manual - Trouble Code List
ManualsLib
https://www.manualslib.com > ... > Service manual
Sharp AR-M207 Manual Online: trouble code list, Details Of Trouble Codes. 1. Trouble Code List Main Sub Code Code E1 00 Imc Pwb Communication Trouble 10 Imc ...
tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Sharp MX-200 Copier. How to remove E7 from my photocopy machine product Sharp MX-200
E7 is only part of the Error Code ' E7-** '.
Sharp MXB200 - E7 10
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E7 10
Sharp MXB200 ; Code: E7 10 ; Description: Shading trouble (Black correction). The CCD black scan level is abnormal when the shading. ; Causes: Improper connection ...
Sharp MXB200 - Error Code
PrintCopy .info
https://printcopy.info > brand=Sharp > code=E7 11
Code: E7 11 · Description: Shading trouble (White correction). · Causes: Improper connection of the CCD unit flat cable Dirt on the mirror, the lens, and the .
I need to program a Sharp tv DVD combo to the cc'd remote.
Remote Control Codes For Sharp TVs
DirecTutor.com https://www.directutor.com > content > remote-control...
The 4 digit codes for most programmable universal remote controls for Sharp televisions are: 0039; 0093; 0165; 0386; 1004; 1009; 1011; 1025; 1064; 1077; 1078 ...
You've visited this page 2 times. Last visit: 13/02/23
Sharp MX-3640N A3 Color Laser Multifunction Printer. Error service code: C1-14.
Question edited for full 'make model (what it is)'.
Error Codes > Sharp > MX3610N > Code C1-14 - PrintCopy .info
https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
SOLVED: Error code C1-14 - Sharp MX5001N - Fixya
https://www.fixya.com > ... > Sharp
Apr 9, 2019 - Code. C1-14 · Description. Main charger trouble (Color) · Causes. The main charger unit (CMY) is not installed properly. There is an abnormality ...
How to remove error code C1-14 For Sharp MX-2501N - Fixya
Sept 5, 2019
Questions & Answers for: sharp error code c1 14 - Fixya
Nov 16, 2019
SOLVED: Sharp mx 3100n C1-14 error code - Fixya
Dec 12, 2020
Error code C1-14 - Sharp Mx-2310u Color Copy/print/scan
Apr 8, 2013
More results from www.fixya.com Missing: 3640 ‎' Must include: 3640
Sharp MX-2630 Error C1-14 - Copytechnet
https://www.copytechnet.com > ... > Sharp
Apr 27, 2019 - Error Code Sharp MX-2630 Error C1-14. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to ...
Sharp MX2640 error C1-14
Jun 20, 2017
Error Code C1-14 on MX3100N
Jul 23, 2011
MX-6240, 7040 (Polaris) with error code C1-0X ...
Jul 17, 2015
More results from www.copytechnet.com Missing: 3640 ‎' Must include: 3640
Codes erreur SHARP - Sharp Photocopieur
https://www.photocopieur-sharp.com > codes-erreur-sh...
C1. C1 10 MAIN CHARGER TROUBLE (BK). C1 14 MAIN CHARGER TROUBLE (COLOR). C4. C4 00 PTC TROUBLE. E7. E7 01 MFP IMAGE DATA ERROR. E7 03 HDD TROUBLE.
Sharp MX-2310U, MX-3111U (SERV.MAN68) Technical Bulletin
https://servlib.com > Sharp > Printer
MX-2310U, MX-3111U (serv.man68). CCE-1425 MODIFICATION OF TROUBLE CODE C1-10 or C1-14 DUE TO DEFECTIVE MC PWB - Sharp Copying Equipment Technical Bulletin ...
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
3helpful
Code for rca rcr311b remote to sharp tv
96helpful
10answers
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Top One For All Televison & Video Experts
Sudeep Chatterjee
Sudeep Chatterjee
Herb Box
Herb Box
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
