LISA CULLEN Posted on Jan 08, 2014
Maintenance code How can I clear out a code Maintenance code FK3 on a Sharp MX-511n?
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Mar 17, 2008
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on May 09, 2008
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Anonymous
  • 95 Answers
  • Posted on Jan 15, 2010
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Anonymous
  • 3 Answers
  • Posted on Oct 11, 2012
SOURCE: Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Anonymous
  • Posted on Apr 18, 2013
SOURCE: sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
