Breaker tripped no power
Check the house circuit breaker to see if it tripped?
Determine if the house circuit your vacuum unit is on has sufficient voltage required.
If your unit has a reset button, press the button and try again.
Cross
the low voltage wire from the relay at the unit with a small screw
driver. If you hear the relay click you need to replace your motor.195 views
