Sony HDRPJ10E Camcorder Logo
T
Tamjid mahmud Posted on Jan 13, 2014
Projector problem my sony hdr pj10e projector is not working. when i turned on the projector it showing dark image. how can i repair ?
5 Related Answers
Anonymous
  • Posted on Oct 10, 2007
SOURCE: repair firewire Sony HDR-HC3
I have a HDR-HC3 and I had the same problem too... This model has ALOT of problems with transferring files and I need to pay $90 to get it repaired... Try it on a Mac, if iMovie cant pick it up it means you have a firewire problem.
Anonymous
  • 80 Answers
  • Posted on Aug 08, 2009
SOURCE: the lcd screen is almost black/ very dark, but i
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Anonymous
  • Posted on Feb 25, 2010
SOURCE: sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Anonymous
  • Posted on Oct 28, 2010
SOURCE: handycam hdr-sr11: LCD blackout
Did you ever find a solution? I have the same problem.
Anonymous
  • 95 Answers
  • Posted on Aug 04, 2011
SOURCE: I have a Sony
E:61:10 is a lens error. Unfortunately, this needs to be repaired by an experienced technician. The only thing that you can try to do yourself is try bumping the camcorder with the palm of your hand near the lens. Try it on the top, sides, and bottom of lens. Sometimes this will work temporarily. If the camcorder was hit or jostled very hard, something in the lens may have moved. The other possibility is that the lens is not making good connection to the main pcb. If the bumping works, I would think it is a connection issue.
Hope this helps.
www.austintelstarservices.com
Top Sony Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
