Dryers Logo
M
Melody Jacoby Posted on Jan 13, 2014
Error code I have a GE Drier Model DBVH510EH0WW Showing error code E62
James Black
Level 1:
  • Contributor 33 Answers
  • Posted on Jan 14, 2014
James Black
Contributor
Level 1:
Answers
33
Questions
0
Helped
8105
Points
47
E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
Read more: http://www.appliancepartspros.com/ge-main-pwr-board-we4m488-ap4980176.html#ixzz2qOlJ8wDy
5 Related Answers
Anonymous
  • 639 Answers
  • Posted on Aug 28, 2008
SOURCE: I have an error code
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Codes can only be repaired by factory service!
If you want clean clothes, call service !
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Anonymous
  • 4323 Answers
  • Posted on Jan 06, 2011
SOURCE: I have a washer dryer
Hi
E62 error code means system contact failure and the user interface board should be checked & replaced. Hope this helps...please post back for further assistance.
Daniel
Anonymous
  • 1998 Answers
  • Posted on Mar 25, 2011
SOURCE: GE dryer dcvh515ef0ww; e61 error
hello this was previously posted on our site by tech rcadieux4444 he writes E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
http://www.fixya.com/support/t137971-ge_dryer_error_code_e61 you can also view this by clicking this link as well if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinon has helped it allows me to help others in similar situations Thanks Rick
Tim Whalen
  • 3076 Answers
  • Posted on May 12, 2011
SOURCE: Hi I have an Electrolux
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jun 19, 2012
SOURCE: What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Top Dryers Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
