Cooktops Logo
A
Anonymous Posted on Jan 12, 2014
Tecnik f code - Tecnik Cooktops
I installed a magnawave cooktop and it dispays an error code which i cant clear
Puzzling. My information says MagnaWave does not make cooktop, only therapy devices. That leaves me to guess it is an induction cooktop.
But I have no brand, model, or error code supplied. Error codes are generally brand specific. Nor is it clear whether the cooktop worked before an error code emerged. The manual for the cooktop should have a troubleshooting section which lists error codes. Here are some cooktops, error codes and solutions. If yours is not one, you might repost with the missing information.
Here are some common error codes and their corresponding solutions:
Fisher & Paykel Induction Cooktop Error Codes:
Er20, Er31, Er47, or Display Issue: Disconnect the cooker, wait for a minute, then reconnect and restart. If the error recurs, note the code and contact your Authorized Service Centre.
E2 (Alternating 'E' and '2'): Indicates overheating of a cooking zone. Switch off the affected zone and allow it to cool. If the problem persists, use only the oven and contact your Authorized Service Centre.
E6, E7, E9, E5: Disconnect the cooker, wait a minute, then reconnect and restart. If the issue persists, note the error code and contact your Authorized Service Centre.
U400: Indicates power supply over-voltage. Verify the correct power supply voltage per the appliance rating label.
Symbol Error: Indicates a malfunctioning control dial. Turn all dials to OFF, then disconnect and restart the cooker. If the error persists, contact your Authorized Service Centre.
Whirlpool Induction Cooker Error Codes:
C1: Input voltage is low. Increase it with a stabilizer or wait if possible.
C2 / C3: Overheating within the device or surface. Allow the unit to cool down before continuing use. If it persists, seek a repair for potential sensor replacement.
F0: Internal error. Wait to see if it resolves by itself; if not, contact customer support.
F2: Overheated cooking area. Remove any cookware and let the area cool.
F4: Re-position the cookware in the center of the cooking plate, away from the control panel.
F8: The cooking process is taking too long1.
Electrolux Induction Cooktop Error Codes:
Quick Fix: Turn the cooktop off and unplug it for a few minutes. Plug it back in and restart the cooktop to see if the error code clears.
Wolf Induction Cooktop:
Sometimes, error codes can be triggered by temporary glitches in the system. Try turning off the cooktop at the power source (usually the circuit breaker) for a few minutes, then turn it back on. This can reset the electronics and clear minor errors.
Samsung Induction Cooktop:
An error code may appear if a button is stuck or the burners cannot detect your cookware. Most information codes and notifications on the cooktop can be resolved with a power cycle. If you have an induction cooktop, make sure you're using cookware compatible with the induction elements.
Remember to consult your cooktop's user manual for specific error code detail
May 13, 2024 • Cooktops
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
1helpful
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
1helpful
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
User Guide worktop make tecnik
I have a full Operating Instruction manual for the Tecnik 23 in. TKH4050 Electric Cooktop.
I would be happy to make a copy for anyone who needs a copy.
Please get in touch.
Wont turn on
new install? or it stopped working try resetting your breaker. for electrical problems call a qualified electrician.
Operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Sparking ignition
switch Is stuck in on position
3helpful
2answers
We didnt get a manual
I got it working! I was messing around with it and I think what did it was just touching and holding the on button for a few seconds!
hope that solves it for anyone else!
Top Tecnik Cooktops Experts
ADMIN Andrew
ADMIN Andrew
gerbee gomez
Paul Carew
Are you a Tecnik Cooktop Expert? Answer questions, earn points and help others
