Washing Machines Logo
A
Anonymous Posted on Jan 19, 2014
F32 Error code - Bosch Washing Machines
1 Related Answer
Anonymous
  • 8197 Answers
  • Posted on Jan 11, 2009
SOURCE: there is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
I have a frigidair double oven and I get a f32 error code. What does that mean?
f3 is a bad sensor and 2 is for lower oven so f32 is a bad lower oven sensor
Nov 08, 2017 • Ovens
Whirlpool cabrio topload f32 error code
f32 is long drain, check all connections on main board, and check pump for blockage,
WHAT IS THE REASON OR CAUSE POSSIBLE FOR WHICH IS IN CODE F32
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
1helpful
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
12helpful
4answers
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
1helpful
There is an error code comming up it is f32
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Top Bosch Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
