Apple MacBook White- 2.1GHz Intel Core 2 Duo, 2GB DDR2 , 120GB SATA HD, Combo Drive ,... Mac Notebook Logo
w
william Posted on Jan 20, 2014
Fix gray screen mac
I have a gray screen with the spinning circle saying its loading but it will not load, how do I reset it
Edwin Burnett
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Apr 25, 2014
Edwin Burnett
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
39532
Points
45
There could be a couple of things to check first. Pull the memory modules and clean the gold contacts with some isotropic alcohol thens restart the laptop, Next make sure each module is working by checking "About this Mac" Hardware, memory. Also if you recently upgraded to a later OS, that new OS may require more memory that the previous system. Finally it may be your hard drive is going ad or already has gone bad. This is a good reason to have a back-up drive for your computer.
5 Related Answers
Anonymous
  • 404 Answers
  • Posted on Mar 12, 2009
SOURCE: apple mac not loading up
might have damaged hard
the computer just told you what is wrong, so the next step is te replace the HD with new one.
Anonymous
  • 56 Answers
  • Posted on Jul 08, 2009
SOURCE: Mac book laptop is not turning on???
Better Take It To Telus To Repair
Anonymous
  • Posted on Jul 30, 2009
SOURCE: apple load screen and loading clock wise circle
i have the same problem
damien729
Damien Gole
  • 221 Answers
  • Posted on Aug 05, 2009
SOURCE: Help wanted to get rid of Blue Screen on my Mac G4 laptop
Hello
If your hard drive is full, then it can cause this problem. To empty the hard drive, deleting the files that you don't want anymore, you will have to use another Mac, and plug a firewire cable between the two.
Then press on the "T" key on your G4 (for target mode). You should see on the other mac's desktop your hard drive and everything in it. You can use the free software Disk Inventory X to get rid of the files that take too much space and that you don't need.
If that's too complicated, you can also try to boot the mac holding the shift key at startup, that will deactivate extensions and you will probably have access to your desktop. Then empty files and reboot.
Hope this helps
Anonymous
  • 25 Answers
  • Posted on Sep 10, 2009
SOURCE: Hey, I have been trying to turn on my Ibook Mac
Sounds like your hard drive is failing.
Try booting while holding down the shift key that will put you into safe mode and run some diagnostics at the same time.
If you have the discs that came with the laptop try booting from them while holding down the D key. That will bring up AHT a built in test for your mac. You can use it to test and repair some of the disc problems you are describing.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
