Sony Ericsson K550i Cellular Phone Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My set's java programs are not running what should i do?
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
16594
Points
138
Try turning it off for at least 2-5 minutes and turn it on. If still not, it may be that one of the games or application installed has a virus or corrupted that also blocks other programs to work properly. So my advise is to delete that recently installed game or application or any suspected file. That happened to me also once.
1helpful
Java will not run Windows 7 64 bit
It depends on the program you are opening, you didn't say? Some software or games don't work on the latest java updates, or 64bit versions. For instance, POGO, a game will not. Limewire, will not. There are many others. It's the program, older software usually, not always.
Write a Java application that finds a. Area and perimeter of rectangle. b. Area and circumference of a circle.Display explanatory text with the value
Did you find a solution for this ?
You haven't received any help because the request looks a lot like a homework assignment and a lot of people are unwilling to do that.
I have some suggestions:
1) You should make sure that you have a working copy of Java. Start at the Java Tutorial: http://docs.oracle.com/javase/tutorial/java/TOC.html
If you do not have a working Java on your machine, follow the link at the top right of that screen to 'Download JDK'. That is the set of programming tools you need to use to compile and run programs.
The Installation Instructions will tell you everything you wish to know. I suggest that you use: http://notepad-plus-plus.org/ to type in programs.
Good luck. Post more on the problem page for more help.
2answers
Can not install java programmmme
Make sure you have your pc set to install javas active x
14helpful
2answers
Unable to run java based program
go google and search for your 5130 java software
2answers
Java won't load on my computer
id suggest that you uninstall java and delete the folder from the hard drive after you uninstall it from the computer, and then clean the registry of any instances of old keys associated to java,then redownload and reinstall java fresh,be sure its the right version for your Vista ( home,Bussniess) Hope this Helps Steve
2helpful
Install games for china mobiles!!!!
First of all let u know that chinese mobile doesn't supports java utilities. for that first of all you have to download a utility that will help other java programs to run on ur system.
It will provide base to run other java......
witout it you can not run those java programs
pls search from the net and download it first.
Jun 17, 2009 • Cell Phones
1helpful
DISABLE AVG8.0
SBICAPSEC runs on java u need to put java into exception list.actualy what i feel avg is some how blocking java to load and without java SBICAPSEC will not ableto run its applelet.go to avg 8.0
in the menu bar on the top of avg window..click on tools->advance settings->exceptions->click on add path
there add the exact path of java where it instaled in ur system..usualy it residesin c:/program files/java.
Hope this should solve ur issues.
Java jre installation not complete
Hi There,
As i understand you receive an error when you run the installed program.
Please uninstall the complete downloaded software and reboot the PC. Then download the latest Java JRE (Java Runtime Environment (JRE) 6 Update 7) to run all Java programs from the link given below,
http://java.sun.com/javase/downloads/index.jsp
Once you have installed the Java JRE, again install the program and test if it works.
It will work!!
Regards,
Olafsson.
7answers
Type of JAVA
java.applet(PersonalJava only), java.awt and sub-packages, java.beansjava, iojava.lang and sub-packages, java.lang.reflect, java.math, java.net, java.rmi and sub-packages, java.security, java.sql, java.text
Top Sony Ericsson Cell Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
Kolbrun...
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
