JBL GTO1202D Car Subwoofer Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not gettin enough bass
I hve 2 12" jbl gto1202d subs amplified with 700 watts jabl mono amp
my problem is i dont what frequency do i need to set on amp??
Anonymous
Level 3:
  • Master 655 Answers
  • Posted on Jun 05, 2009
Anonymous
Master
Level 3:
Answers
655
Questions
0
Helped
320603
Points
2081
Hello saini_jatt_2, On the JBL3501 700 watt monoblock, you have adjustments for low pass and a setting for boost marked DBO, allowing you to select and boost the frequencies sent to the subs. If your amp is not the 3501, but a different JBL amp, the settings may be different. Set the LP to either the white dot (about 100Hz) or slightly below to about 80Hz. Set the HP to about midscale or slightly higher. Set the boost to wherever the bass sounds best. One other setting that will affect bass volume is the "input level" or gain control. It should have been properly set by your installer, but you can "tweak" it for best performance. Turning it up increases the sensitivity and matches it with the output from your head unit. Too high will cause distortion. Too low will result in less bass. So you want to set it just to the point that you begin to hear the distortion and then back it off slightly until the distortion disappears. Hope this helps.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Andrew
ADMIN Andrew
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
