Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
p
penagosfaby Posted on Feb 17, 2014
Where is the eject button on a macbook - Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Mark Salvo
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Feb 18, 2014
Mark Salvo
Contributor
Level 1:
New Friend:
Answers
23
Questions
Helped
2404
Points
50
Top right of the keyboard. You can see it in this picture.
where is the eject button on a macbook - 04f4d574-ac28-4e2e-a86b-ee4ed250f57e.png
4answers
How to eject cd inside macbook pro drive?
Hold down the right click and restart, or attach a mouse and hold down the right click and restart holding down the eject button.
Eject command for macbook pro
the eject button is at the top right of the keyboard, but you may also drag to the recycle bin and it will eject.
How do I eject a DVD from the MacBook Pro?
Press the eject button on the keyboard, top right-hand side, just above delete button.
You could also try going to your HDD, click on CD Drive, right click and eject.
Hope this helps.
1helpful
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
A dvd has become stuck in my macbook and when i reboot, the screen remains blank and will not start up
If it is physically stuck, you will need to take it in for service.
If you just need to eject it, hold down the eject button or the trackpad button as you power on and continue to hold it down until the disc ejects.
5helpful
MacBook Pro intel, CD stuck not mounting or ejecting
while restarting, push and hold your mouse button during the entire boot sequence. this will force the ejection of the cd.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
3helpful
2answers
APPLE MACBOOK WOULD BOOT. THE BOOT CD IS
unfortunately on the newer mac computer including the macbook you cannot boot to open firmware but there are other options
option 1)simply try holding down the mouse button or track pad button during boot after the first chime is sounded this will instruct the computer to eject the cd through the firmware
option 2) you can bypass the cd boot by holding down the option key after the first boot chime another simple solution this will allow you to choose a startup disk during...startup after which you can try the eject button on the keyboard or select the disk in finder and eject via trash can or eject symbol(symbol located in the open folder view of finder)
option 3) there is also a manual eject button though it may be harder to locate as they have change placements of it over the years however it can usually be found by probing the top center or far right of the cd slot with a paper clip just be gentle you don't want to damage an expensive piece of equipment by just carelessly jamming metal in it
you may want to try searching apple with your particular model and search for manual cd eject
best wishes, Crash
1helpful
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
4helpful
4answers
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
