Konica Minolta Bizhub c203 Copier Logo
A
Anonymous Posted on Mar 03, 2014
Error code 7255 - Konica Minolta Bizhub c203 Copier
Norman Weimar
Level 3:
  • Konica Minolta Master 7,080 Answers
  • Posted on Jan 15, 2016
Norman Weimar
Level 3:
Answers
7080
Questions
Helped
1997807
Points
12012
No such code for the model c203
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sir MRE Konica 7255 mn likha ah RHA hy report code sc90-01 plz helpe ks tara thek ho ge
Automatic duplex drive (What allows double side copies) motor or board. check the motor in 47 mode,
Konica minolta 7255 error code sc 77-02
http://www.fixya.com/support/t12138228-konica_minolta_7255_error_code_sc_77_02
I can not download drivers for the ms 7255 msi motherboard from the msi website
The MS 7255 also known as the MSI P4M900M2-L
Here is the direct link to the MSI support page where you can download the drivers and manuals for you Motherboard.
Hope this helps! P4M900M2
Error code sc23-03
DRUM MOTOR ERROR.
Check the cleaning blade the cleaning roller or the toner recycle system driven my the drum motor. to check the cleaning blade and toner roller remove the drum cartridge. Drum could flipped the cleaning blade toner roller could have jammed or motor bad great jam. worst case control board fault.
3answers
Error code sc 23-04
What model is this machine?
CODE 02-01 SC23-04
Sir/Mam, please check the model and the code looking at service manual for the Konica Series 7255 not such code per what model you currently have this problem with
1helpful
5answers
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
4helpful
2answers
Driver fr msi micro-star ms- 7255
buenas noches, la siguiente es para solicitarles el pack de drivers de la tarjeta madre msi ms-7255
la cual necesito, de antemano,,,,,,gracias!!
1helpful
2answers
Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
