Sharp 25L-S100 25" TV Logo
w
wm scott tordsen Posted on Mar 09, 2014
HAVE NO REMOTE
How do i get close caption
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
5answers
Sharp Aquos LCD TV 52"
Does your cable company support CC?
1helpful
How to turn off closed captioning without original remote
You must have its remote control to close the closed captioning function.
Cannot remove the closed captioning
You must have its original remote control to close the closed caption.
Can't turn on memorex MT2012 Closed Captioning using a universal remote
You must have its original remote control, which will have 'CC; button on it. you have to press this button once to cancel the Closed Caption option. If you can acccess the Menu of the tV by your present universal remote contro,; get into TVs Menu option, surf through, come to closed capation adjust window, and cancell [OFF] the closed caption option.
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
9helpful
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
4helpful
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
7helpful
3answers
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
2helpful
2answers
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
