Video Game Consoles & Games Logo
Posted on Jun 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Math exponent
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 117 Answers
  • Posted on Jul 15, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
117
Questions
7
Helped
30072
Points
192
Correct me if I'm wrong but are you asking what an exponent is? If you are an exponent is the small number to the upper right corner of a number. the larger number is multiplied by itself by the smaller number (ex. large 4 and small 5= 4x4x4x4x4= 1024)
What is the answer to to this (x^5)^3(x^3)^4
We have to follow BEDMAS, the order of operations, where brackets are first, then exponents, followed by division and multiplication, and finally addition and subtraction.
Also, we have to use the exponent law of an exponent to an exponent, we multiply the exponents with the same base.
If we forget this, we can always do it the long way.
(x^5)^3 = (x^5)(x^5)(x^5) = x^15
Similarly, (x^3)^4= (x^3)(x^3)(x^3)(x^3) = x ^12
Now that we have done the exponents, we can multiply x^15 by x^12 and get x^27.
Good luck.
Paul
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
3helpful
What is the meaning of MthIO in a CASIO calculator?
Math Input/Output. This mode shows the input expression and the result in more commonly seen in math books, with raised exponents, numerator stacked above denominator, and so forth. The other mode, LineIO for Line Input/Output, shows everything on one line.
1helpful
I need help...i dont know how to put in exponents, negative exponents and i dont know how to put in fractions
For negative numbers (not just exponents), make sure you use the (-) key just to the right of the decimal point key, not the - key for subtraction.
For what follows I'm going to assume you have at least version 2.53 of the operating system for the 84Plus. If you have an older version, I STRONGLY recommend you update it:
http://education.ti.com/educationportal/sites/US/productDetail/us_os_84plus.html
You can use the "n/d" command in the MATH/NUM menu to enter the division bar. For example, to enter 1/2, press 1 MATH right-arrow ALPHA [D] 2 ENTER. If you just want the number, you can also enter it as 1 / 2.
You can convert a decimal number to a fraction using the >Frac command in the MATH menu. For example, to convert 0.2 to a fraction, press . 2 MATH 1 ENTER.
5helpful
2answers
I'm doing radicals I need to type an exponent into my calculator that goes before the square root not after. how do i do that (5) as an exponent square root of 32.....the answer is 2 but how do i type it...
Use the xth-root function to compute any root. It's the fifth entry on the MATH menu, which you can get by pressing the MATH key. The fourth entry on the same menu gives you the third root without needing the 3 to be specified.
For example, to compute the 5th root of 32, press 5 MATH 5 3 2 ENTER.
4helpful
2answers
I need to know how to enter anything above cube root into my TI-83.
  1. Use the universal power key marked with [^].
  2. To avoid problems if the exponent is an expression, enclose it in parentheses.
  3. To enter any power type number^(exponent)
  4. If exponent is negative use the (-) change sign key next to the dot, below the 3 key.
  5. To calculate the roots (cubic, fourth, fifth, etc.) roots use the fact that a root of n-th order can be represented as ^(1/n)
  6. Ex: cube root of 27: 27^(1/3); square root of 64 : 64^(1/2) or 64^(0.5)
1helpful
What do i key in for 2 to power of 12??
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
2helpful
2answers
2 to the twelve power equals what
In the exemples above I used 2^12. But you can enter any base (2, 3, 5.5, 16/47, ) and any exponent ( 12, 13/48, 0.007654, even negative values).
Hope it helps
I JUST GOT MY ti-8today and don't know how to use it
To do fractions, input like this:
(1/3)+(4/9)
Granted the answer is a decimal... But you should be able to convert that to a fraction using what you've learned in math class.
PI sign: Just press [2nd]and then[^]. And voila, instant π! Exponent:enter more complicated expressions involving exponents using parentheses and the negative sign.
For further guide read: http://www2.stetson.edu/~mhale/teach/ti83.htm and http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&appId=6124&tabId=2
Please rate this!!
Exponent Sign
To write 50 exponent in math mode, type your number then hit the key that has (x with the solid white exponent key). It's between the (x squared key) and the (log key) then you can enter the number 50 for your exponent. You can also hit the (x squared key) delete the 2 exponent and type in the exponent you want.
Top Capcom Video Game Consoles & Games Experts
john h
ElDopa
ElDopa
Anonymous
Are you a Capcom Video Game Console and Game Expert? Answer questions, earn points and help others
