Nokia 1209 Cell Phone Logo
R
ROBIUL ISLAM Posted on Apr 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Security problem i forgot my security code imei no.354209/03/311697/0 pls help me as soon as possible
Mohd Mohsin Khan
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Apr 02, 2014
Mohd Mohsin Khan
Expert
Level 2:
Scholar:
Answers
91
Questions
Helped
6818
Points
213
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
  • Volume Up + Home + Power
  • Volume Down + Power
  • Home + Power
  • If none of the above work, do a web search for your phone's model plus "recovery mode".
  • 3-
  • Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
  • You will be asked to confirm the factory reset.
  • 4--
    Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
    • thank u!
5 Related Answers
Anonymous
  • Posted on Sep 15, 2008
SOURCE: Resetting Security Code
forgot password need master code....IMEI no is 354813017033711
Anonymous
  • 110 Answers
  • Posted on Sep 26, 2008
SOURCE: Forgot my security code
The default security code for Nokia is 12345
IMEI: 356438012346609
Master code: 0631367461
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
Anonymous
  • Posted on Nov 07, 2008
SOURCE: unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
Anonymous
  • 421 Answers
  • Posted on May 29, 2009
SOURCE: nokia 3110c security codes
IMEI: 359309023772181Mastercode: 2607147471
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
aysaam
Resolution IT Dubai
  • 541 Answers
  • Posted on Jul 02, 2009
SOURCE: I forgot my security code Nokia 5310
Hi Friend,
The IMEI number you have provided is not correct ,From the below link u can
collect the security code by providing your IMEI number,to get the IMEI number umust
just*#06# or at back side of the mobile u will have serial number is as same as IMEI
Number,
http://mastercode.nokiafree.org/
or
if these all not supported then kindly inform it to your serviceprovider,they will make a reset to your security code from their backendprocess,since they keep all the codes in a secure manner.
Kindly check it and provide the status
Thank for using Fixya
Regards,
Ayyasam
Top Nokia Cell Phones Experts
Kolbrun...
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
