Gaggia Titanium Espresso Machine Logo
Jennifer Yu Posted on Apr 02, 2014
Replace microswitch need to know how to replace the microswitch.
  • Anonymous Apr 02, 2014
    I got great help from Gaggia service and i have a working machine.Their address is info@gaggia-service.co.uk
Code pe on samsung dishwasher
Error Code: PE
Reason For Error Code: Half-load error
Repair and or check: Unplug the dishwasher. Reconnect any loose wires on the distributor plate motor and microswitch. Replace the wire harness if it is damaged. If the wires are not damaged, replace the distributor motor assembly. This includes the distributor plate motor and the microswitch.
Parts Needed: Distributor motor assembly
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
My Saeco Royal Professional won't grind: "blocked grinder" message
Hello, I had exactly the same problem. In my case, it seems that the grinder was not ejecting the grounds into the doser with enough force to move the pressure plate and trigger the microswitch. My grinder motor might be wearing out, but I decided to try increasing the sensitivity of the microswitch before I spent so much. I replaced the microswitch, but that didn't solve the problem. Instead, I added a spacer (~2mm, but you'll have to play with it to adjust the pressure for your switch) between the doser pressure plate lever arm and the microswitch. That has been working very well for the last month. Very occasionally I get the same message again, but if I tell it to brew again the second grinding succeeds. I hope this helps!
I got the replacement microswitch at http://www.saecoparts.com/
Logitech mouse left button does not work
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
4helpful
2answers
Boot will not open with handle or remote on my 2005 Ford Focus 1.6 ghia saloon.
I know it's late, but you have a bad microswitch in the handle. I had the same problem with my 2005 focus. It needs to be replaced, that's it.
6helpful
2answers
2004 Mini cooper convertible roof
Make sure that the microswitches in the rear trunk are all depressed. There is one where the parcel shelf (the cover that covers the view of the trunk from the outside) sits on the left that is usually the problem make sure that it is sitting on the microswitch (pull down on the closest side to you so it pivots forward and sits on the microswitch. Then make sure that the latch on the left side (drivers side) of the rear that allows easier access to the trunk switches the microswitch there. now close the trunk and try the conv top. the parcel shelf, the rear access latch and i think the trunk switches need to be depressed for the top to work. I know at least the first two.
Broken volume microswitch
At only about $10 today for a brand new complete unit, I wouldn't bother. You'll pay at least that much with shipping for the replacement switch.
Or -- perhaps someone here who has had a failure on their unit (there are several) would just send it to you, and you could swap the switch from one to the other.
4answers
Self Propel
Determine if the wheels spin freely or if there is resistance. Sounds like you need a replacement belt for the drive. If you need help with installation, let me know.
2helpful
2answers
Salton expresso cappaccino maker microswitch
The Honeywell V7-1C17E9 microswitch is a form/fit replacement for this Defond switch. You can get it at www.alliedelec.com. I had one fail in a Delta DT1600E Pressure Washer. The replacement switch worked great. Good luck.
Top Gaggia Coffee Makers & Espresso Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
