Epson WorkForce WF-7510 All-in-One Printer Logo
A
Anonymous Posted on Apr 06, 2014
Misaligned text print shift left then right approx 1/8" going down the page. frequent "Print Error" indications.
5 Related Answers
Anonymous
  • Posted on Mar 15, 2008
SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
Anonymous
  • 150 Answers
  • Posted on Jul 18, 2008
SOURCE: epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
Anonymous
  • Posted on Oct 30, 2009
SOURCE: I have an Epson stylus sx205. When I try to print
My Epson SX205 shows ink cartridges empty, when they are not and or does not recognise them as being compatible. Is there software available to over ride this problem
Anonymous
  • 5 Answers
  • Posted on Mar 25, 2010
SOURCE: Epson LQ-2180 continuous printing problem
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Davecapt
  • 26 Answers
  • Posted on Apr 19, 2010
SOURCE: red light stays on and printer won't print
clydeanrev, First cancel everything that is waiting to print. Go to printers and faxes, open Epson C60, click printer and cancel all documents. That should make your green light stop flashing and stay on. The red light staying on means paper ran out, ink ran out or paper is jammed. Take the paper out and put it back in. Take the ink cartridges out and put them back in.
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
