How do I use the self cleaning function to keep the iron clean
SOURCE: how to clean
heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
SOURCE: Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
SOURCE: Rowenta DZ5080 iron -lost manual - how do you go
I prefeer to put calgon in the tank where you put water.
SOURCE: self cleaning instuctions
Hello there, my iron laser rowenta pro is dirty and dont have my book again, some red brown water is coming out, please i need help thanks
SOURCE: I need to use the self clean on my Rowenta
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
