Sewing Machines Logo
A
Anonymous Posted on May 01, 2014
Error code e005 - PfaFF Sewing Machines
Singer Futura XL-550. Error code 08
There is no data available on Error Codes in general or on Error 08.
https://www.google.com/search?q=Singer+Futura+XL-550.+Error+code+%2208%22
https://www.google.com/search?q=Singer+Futura+XL-550.+Error+codes
It is not even in the Service Manual, which does mention codes, but not 08.
Error code list
Error
06
Feed step motor
09
Zig Zag Step motor
16
Cutter step motor
https://www.manualslib.com/manual/739440/Singer-Futura-Xl-550.html?page=31#manual
If the error goes when you remove the embroidery unit is is likely to be a positioning error when the machine is lost to where the needle is in position to the frame.
2answers
What does an E1 Error mean on my Kenmore sewing machine
The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error code. NOTE: Be sure to unplug the sewing machine before you access any internal parts.Jun 10, 2008
https://www.searspartsdirect.com/diy/error-codes/sewing-machine-repair/1234596/kenmore-385-model-sewing-machine/0582
2answers
Error code E-06 cant stop needle running servo WR561-1
Brand new? Take it back where it was purchased!!
Search for:
Make Model error code
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
E004:
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
E005:
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
3answers
Error code & solution
HI there
can you please inform us what's model of control box? there is no error named E815 !!!! please we need more explain to help you.
thanks and best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
F4 code
Usually the error codes are shown as like E4 which would be E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left. If you have any further questions or feel that the error is an F error code instead of an E error code message me back and I will look futher into your F error code but even if you click this link which will bring you to the brother error message site click here http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000000/000064/faqh000064_000.html?reg=us&c=us&lang=en&prod=hf_ce5000eus&Cat=56 it still basicly says the same thing and the errors are shown as E's. I await your reply if you have any further questions Thanks Rick
Top PfaFF Sewing Machines Experts
Kirk Augustin
Kirk Augustin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
